Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Found the problem in the charging system..... Just not a 100% sure if it's the stator or voltage regulator tested the stator and I have no resistance between the stator and engine... From what I read it should read infinite or OL on the meter.... Also there's no voltage at idle as the bike revs it goes to 40 volts then drops back off and only reads 11.6 volts at the battery
Repost this in general chat with all your bike info and test performed!
