Help me dear Lord
Help me dear Lord
Ok so this is the problem i ran into tonight.
Long story short, the rear, left turn signal found it's way out of the clamp and wants to rub itself against the wheel.
This mad the wire bare. when i went to check the wire out I had the keys in the slot ( idiot me, yes i know to disconnect before blah blah blah) when i checked the wire it crackled and i found that it was bare.
Now what i'm dealing with is a bared wire, my head light does not come on, nor high beams. my turn signals flash but they are not on anymore, the only thing that actually works is my tail light, which is primarily on and shows my braking.
I have an 09 street bob. is this just a fuse or should i seek a mechanic?
Update
Yes, I used the spare fuse for the lights and make the daytime running lights work. i wrapped the bare wire with some electrical tape, and i went off to the shop, my turn signal was acting funky, the left side would stay bright and not shut off for a while....then all of a sudden the turn signal works fine ? ><
I got an appointment at the shop pretty much its a cut splice and solder job which to me, I'd rather leave that in the capable hands of someone who knows what theyre doing.
