07 with Wide Band O2
Cold as hell out and there seems to be a fair amount of activity here today so I thought I would toss this out.
What (if any) option are there for running a Wide Band O2 Sensors on an HD. Installed one on my 69 Camaro and the benefits are a no brainer. It's interacting with the ECM, used for closed loop operation and data logging on Holley's system.
I know there are lots of setupsyou can install for logging purposes. But is there anything out there (or in the works) where it interacts with anECM?
RE: 07 with Wide Band O2
Thanks for the info...It appears that theDaytona Twintec is not used direct by the ECMbut more of adata logger which can then be used to adjust tables, not really a closed loop system?
I did not knowthat Thunder Max had switched to Wideband control,So I revisited thierwebsite...looks like you need to run thier ECM,otherwise it appears to be what I was looking for.May have to put theThunderMax on the wish list for now, as I'm already invested in SERT.
Sounds like you are looking at the DTT TwinScan product with the Wego2. That will work with your factory ECM . That products helps you gather data to use in changing the MAP of the ECM with your SERT.
DTT also makes a autotune product that replaces the factory ECM also.
Correct me if I'm wrong...
On an 07 you wouldneed to add aditional bung fittings to run the Wide Band sensorsto gather data and still use the narrow bands to provide input to the ECM? While with the Thunder Max you replace the Factory Narrow Band with Wide Bands sensors along with thier ECM.
Thanks
Chris
Thanks
Chris
ORIGINAL: cjuetten
Thanks
Chris
Thanks
Chris
http://www.aempower.com/ViewCategory.aspx?CategoryID=81
06-14-2018 10:20 AM
cruiser85257
27
01-31-2008 06:37 PM
