Light Issues
Light Issues
Last week I became aware of some illumination issues. I don't know for certain that they all arose at the same time, but that seems to be what happened.
2009 Road King
The low beam headlight does not come on, and neither do the passing lights. The headlight will illuminate on high beam but, of course, the passing lights are not on with the high beam. Also, the left front blinker does not illuminate as a running light, but it does blink when the left turn signal is activiated.
It does appear that I took a rock to that blinker, as the lens is cracked, so the bulb could have been damaged.
Is it likely that they low beam bulb is burned out and that because no current is going through the headlight the passing lights are also not lighting up? What do you think?
Thanks,
2009 Road King
Thanks,
