help
help
my 99 ultra just started shuting off on me a week ago on my way to work the bike just shut off like i hit the kill switch. i tried to re start it it turned over but woudn't fire i shut off the ignition turned it back on started it happend 3 time that morning. on the way home just 1 time the next time i rode it no problem today 3 times this morning not 1 time this afternoon ive wiggeled wires and looked around but i can't get it to do it it's random but it seems to do it early in the morning when it's cold not so much after it's warmed up outside real strange
thanks
francis
thanks
francis
BAS = Bank Angle Sensor
TSM = Turn Signal Module
The BAS is inside the TSM and usually when it is working correctly will shut the bike off if it tips over past a certain degree.
However if faulty it can shut the bike down just going over a small bump etc.
if you keep a jumper wire with you when it does it,go from hot side of bat to hot side of coil if it starts back up with no problem it would be lose connection somewhere but remember when you do this the only way to kill bike will be to pull wire back off.. but that bypasses all switches and connections but not mods.So if it starts up and runs fine it would be lose connection somewhere..
randyw
08-29-2020 12:06 PM
12SKULZ
05-23-2013 04:49 AM
