Front signal conversion prob
Changing my front dual filament lights with a single filament one on my 04 N/T. Old light have 3 wires (ground-turn-signal) and the new light has just 1 wire to power just the signal, housing grounds itself to the fork. I open the stock plug under the gas tank and do some checking to make sure new light work ok, and when i try the new signal light (leaving the ground-power wires open) it flashes normal about 4 times then both front and rear start flashing fast, real fast.Whats the problem with this? Im not really electricly inclined, so go easy on me .
RE: Front signal conversion prob
When it flashes fast like that it is the TSM/TSSM telling you that it is detecting a problem in the circuit (which is you changing the wiring around). You also most likely set some codes. If so, the signals will flash 4 times when you power the bike up - just like you turned on the flashers.
You need a device like the Biketronics Frontrunner, it will simulate the lost load that is triggering the code and allow the single filament to act as both running lights and turn signal..
http://www.biketronics.com/item.html?PRID=1112054
Well i did as you suggested, ordered the frontrunner, waited a week for it to get here, ran downstairs and hooked that suker up. I must say installing it was a breeze and the signal lights..............................
.......................they blink just as fast as before, didnt do a frigging thing. $$ down the crapper i guess. What do i have to do to get these working right???????????????
ORIGINAL: slugo
Tom
stev0n
02-19-2011 09:01 AM
car5car
11-27-2009 08:00 AM
