Who uses trailer Isolator plug
Just got a time out trailer for christmas was looking at plugsto forwireing the trailer , Im woundering if it's nessary to install isolator plug? I have the got the connector that plugs into the harness with the wireing marked for the lights.I plan on fuesing the tail lights.
[IMG]local://upfiles/3159/053375CD282F4239873E2F96D92FE2BA.jpg[/IMG]
RE: Who uses trailer Isolator plug
Unless your trailer has all LED lights I would use an isolator. A good isolator will pull its current directly fron the battery. The wiring circuits for the MC lights barely are of capacity to run the factory lights. I have done the trailer lights both ways. On my last bike I wired direct initially. I found the light circuits getting warm when wired direct. I changed them to an isolator and the worked great. You can still use the connector to get you connection to the isolator from the oem wiring.
TeamMudd
Gear and Other Items For Sale
07-16-2017 05:16 PM
