Big trouble in little China..
Well, maybe. I figured one day i would need help worthy of a post, and here it is. I searched and nothing really helped, hence my post
Today I decided to install apes on my 05 FXSTDI. Believe it or not, it wasn't terribly difficult at all. I disconnected the battery then went to work. After running the new t/i, clutch and brake cables, I weaseled the wiring through the bars with the extensions already affixed. Plugged them into the harnesses, hooked up the battery and tested functions of the signals, hazards, horn and hi/lo beam...all checked out so I disconnected the battery and finished the project.
Once complete, re connected the battery and went to start. Wouldn't start, forgot to add gas (dummy light on)...added gas (dummy light off). Still continued to NOT start. I had to scratch my head....then noticed, hrmmm....the engine light isn't coming on then off for me to try and start it. wtf? the fuel pump isn't making any sound. peeled tank back a bit, looked at wiring harnesses, wiring in general, the fuse(s) and everything looked "okay" to me. Pulled off the center console, everything "looked" good there too. Still nothing. tried disconnecting the battery for about 5 minutes, repeat start cycle...no fuel pump.
Honestly, I don't have a clue where to start past what I have already done.
