Help with location of these ignition/engine control wires...
I am installing a scorpio alarm and for the ignition disable feature I have a few options for splicing it in to the ignition/engine control. I can't find the location of any of these wires or their description/color in my manual and am wondering if I can get some help on very specific descriptions. Here are the options listed:
1) positive lead wire or ground on fuel pump
2) positive lead wire on fuel injection system
3) positive wire that goes to the ignition fuse in fuse box - it goes on to say here that "this should be either a 10 or 15 amp fuse labeled IGN [carbureted bikes only]) and I don't know if this whole option #3 is only for carbed bikes or just the labeling reference.
4) ground wire from ignition module.
5) positive wire from ignition module to ignition coil.
Also, which would you recommend?
Thanks
Thanks
jacknthebox
04-22-2013 09:03 AM
