What comes with the sert?
RE: What comes with the sert?
You get an interface "Key", a Data Disc with the manual, Cal Listing and SERT Library......
That is all in a small white box....
If you want a copy of the map that was installed in your ECM, you need to ask the Service Dept to make you a copy from their files (If they saved it properly).....
But also, they need to have a burner installed on their SERT PC.....
