I want to know why my 2011 fat bob....
Oil level? No. First thing I'd do is drive it through their front door...kidding of course. Besides that, check the intake that the bolts are all tight. Everything look normal? Clear? After that, see suggestion one. I'm clueless.
did you have the dealer do the service? was it idling okay when you picked it up? if not, i wouldn't have accepted it from them until they made it right. it idled when you brought it in, should idle when you pick it up.
but, since you have it now, check all the simple things first. any intake leaks, loose plug wires, is the iac dirty? bad gas? bad plugs? constricted air filter?
If you posted an image I cant see it. It appears to be bad or low octane gas I put 91 like normal and a bit of boost shes idling fine now. Its kind of funny that it should happen after my 20k service. (not ha ha funny).
Thanks for info
GoGetter5832
01-13-2012 12:31 PM
