2007 Road King quit while running wont start
Gentlemen,
Just Purchased and was on my second ride and was within 1/2mi from home and bike just quit as if no fuel, all electrical seems to work and turns over. Checked codes and got a (S) U1016 and a (SP) U1016. Anybody know which direction to point me? Checked all connections seem to be good. Is the ECM toast??? Are my FOB's causing this???
19k, Power Commander III, True Dual Rineharts, Dual FOBS
first things to try would be in this order.
1. pull the fuses 1 by 1 and check for corrosion
2. pull the ECM connector off the ECM and look very closely inside of there for corrosion or misaligned pins
3. work your way from the ECM backwards to each plug along the harness and check the pins for corrosion or alignment issues.
when you plug the ECM and other connectors back in, make sure to use dielctric grease inside that fitting to keep moisture out of it.
Did you ever find the problem? I am experiencing something similar. However mine died @ home thank god for that. I did notice on my way home from work it did not sound right but ignored it because I thought i was imagining and didnt experience any loss of power. When I was gettimg ready to go to work again it started right up and idled for a few minutes and than died...It cranks over but thats all it will do....please inform what you found
nickgyver
03-30-2014 12:48 AM
klwsparks
02-21-2012 11:23 PM
