PCIII question
PCIII question
I have a pcIII usb on my 03 duece and just installed a set of pipes and stage I air filter kit.Everytime i connect it to my computer it says no power commander and will do nothing .Any help would be greatly appreciated.Oh by the way i am using the 9 volt (fresh)battery and bringing it inside to swap maps.
RE: PCIII question
if the PCiii is on the bike while you are trying to do this... start the bike. on my bike, just turning on the electrical system doesn't seem to do the trick. I have to start the bike, then start the software on the computer.
I have not used the battery option, but I would venture to guess you need to get juice to the unit first, then start the software (just like when on the bike).
just read your post again... not doing it on bike. Anyway, get juice to the PCiii, connect the cable to the PC, you should get some indication that you plugged in a USB device. Then start the software. If that doesn't work, call the guys at Powercommander.
anubisss
06-25-2009 07:29 AM
