question about roll off switch
installing a cruise control and every thing electronical looks ok but module will not pull or lash the cable. my question is can I run a small wire across roll off switch(rt frt neck) to bypass? with out damaging switch? double checked everything and dont have a ohm meter. diagnostic codes are all fales-pos tach,rpm.
thanks
thanks
RE: question about roll off switch
If the switch is continuously "made" for some reason and the leads are connected normally, it's indicating a rolloff condition. Disconnect one of the leads attached to the roll off switch to "bypass" it. That takes it out of the circuit and simulates "not made" therefore should allow for lash adjustment.
thanks
this has been frustarating but its winter and its just a friggin cruise control so will be patient.
freind is stopping by today that has same bike and is an electricion by trade. has an ohm meter and will go over the abc's again to find fix.
thanks again for help will keep posted
