Turn signal problems
My signals work fine unltil the rpm's are up under load only. If the rpms are low or high in neutral they blink. When I am riding with higher rpm's and I push the signal button, they stay on steady until the rpm's drop ( then they start to blink ) Any suggestions on what is causing this??
thanks,
David
thanks,
David
RE: Turn signal problems
the difference between high and low rpm could be the amount of juice from the charging system. (more at high rpm.) check voltage at battery to see if its charging to much at high rpm. or if you have a rubber mounted engine check for wiring getting pinched or pulled under load.
