Bosch 02 Sensors - Cheap
Old 12-11-2011 | 09:26 AM
TXSailor's Avatar
TXSailor
Default Bosch 02 Sensors - Cheap
The ThunderMax Auto uses Bosch Wideband O2 sensors as do many other "autotune" systems. These sensors are widely used in many other types of engine applications and come wiht various connectors.
Although I have not had to replace my sensors, I did find the following two sources for the Bosch O2 Sensor part number 0-258-007-057 (sometimes known as an LSU-4 or 17014) which is the one used by ThuderMax/Zippers. VW uses the same sensor (their part # is 021-906-262B) so if you get in a bind, any VW Dealer should be able to help.
http://www.bmotorsports.com/shop/pro...roducts_id/345
unit price $67
http://oxygensensor.net/bosch_o2/17014.php
unit price $48
You can buy all sorts of O2 connectors, etc from these places. With $ tight in today's economy, there is no reason to "over pay" for anything.
D
Rob Roy's Revenge (04-22-2023)
Old 12-11-2011 | 09:29 AM
davidwideglide06's Avatar
davidwideglide06
I had to replace the front o2 sensor and bought mine at the local autozone parts store for fifty something.
Old 12-11-2011 | 09:38 AM
TXSailor's Avatar
TXSailor
Even better. I can't understand why folks are buying these things from "vendors" at twice that price.
Did you just ask for the Bosch Part number?
D
Old 12-11-2011 | 09:48 AM
davidwideglide06
Yes, found the Bosch number in a search and just went in and gave them that. Perfect match.
Old 04-21-2023 | 09:24 PM
DAtkinsoFLHTK's Avatar
DAtkinsoFLHTK
6th Gear
Know this is a VERY old thread, but it helped me out replacing a bad front O2 sensor on my 2015 RK.
Installed TMAX ECM 6 months ago, the bike started running RICH a few weeks ago, hooked up the laptop to the bike, front AFR was pegged at 19.36 - swapped out the connections (rear to front) tada - bad sensor.
OEM from TMAX was $130 + 5-10 days shipping
Found this thread & bought 1 for $35 @ Oreilly's
Installed w/out having to remove the pipes & out riding this evening.
Thx for the info!
EXACT REPLACEMENT
17014 Bosch LSU4.2 WideBand O2 Sensor
Old 04-21-2023 | 10:56 PM
Tcrafty's Avatar
Tcrafty
Thx for the info!
EXACT REPLACEMENT
An old thread with some great info! IMHO, threads like this one need to bubble up to the surface from time to time.
The following 2 users liked this post by Tcrafty:
DAtkinsoFLHTK (04-21-2023), porkster (04-23-2023)
Old 05-02-2023 | 12:15 PM
Road King Kid's Avatar
Road King Kid
That is interesting. I just checked Oreilly for that very same part number $107
HardyHarHarley
05-18-2023 05:14 PM
lmarkie
Exhaust System Topics
06-03-2019 05:31 PM
SavageChopper
05-27-2014 10:15 AM
nevil
06-05-2010 04:55 PM
07flstc
11-23-2007 04:10 PM
