Idle question
Old 12-04-2006 | 01:30 AM
Devil Dog's Avatar
Devil Dog
Default Idle question
I have an 06 SG. I have installed Thunderheader slipons, SE stage 1 intake, HD download #1, and a Cobra FI200R fuel management system. When the bike is sitting and idleing, the rpms are pretty steady at 1000. But, every few minutes, the rpms drop about two to three hundred and it sounds like it wants to die. Then, just as quickly, it comes back up and stays at 1000 until it does a again a few minutes later. It almost acts like a load is being placed on it momentarily. Any thoughts?
[IMG]local://upfiles/4779/A470EBA0F4B94181B2156A7323941373.jpg[/IMG]
Old 12-04-2006 | 01:35 AM
Shovelhead Bob's Avatar
Shovelhead Bob
Default RE: Idle question
Fer Sheittz and Grinnz, take the Cobra out of the loop..........
If the idle drop is still there, check the fuel pressure, injector connections and operation of the ET sensor/IAT sensor....
If the idle stays where it is supposed to be, it is the Cobra unit......
Old 12-04-2006 | 01:45 AM
Devil Dog's Avatar
Devil Dog
Thanks for the quick response. I guess I should have mentioned the rpms fluctuated like that before the FI2000.
[IMG]local://upfiles/4779/92D6340800A042F5A96DBCAEA4E0635F.jpg[/IMG]
Old 12-04-2006 | 01:54 AM
Shovelhead Bob
Injectors, Fuel pressure, IAC/ET/MAP sensors AND the associated wiring and connectors are where to look......
Life sure would be easier if you had a SERT.... Then you'd have the ability to "Data Log" and see all of your parameters.....
Might have to take it to a shop that has Digital Tech, or you can buy the Datona Twin Scan, and do it yourself......
Old 12-04-2006 | 01:57 AM
Devil Dog's Avatar
Devil Dog
You almost went over my head with that reply. I am just learning about these twin cams. I also wanted to ask how the injectors go into the place where they mount. From the manual, it looks like they just slip in and have a clip holding them. I noticed when I was hooking up the Cobra that one of them (rear cylinder) seemed like it turned a little. If it screws in, it was lose. If it just pops in and has a clip, it was ok.
Old 12-04-2006 | 02:10 AM
Shovelhead Bob
From a Retired Gunny, I'll break it down "Barney Style".........
Injectors are press fit into the manifold, they are held in place with a fuel rail and 1 clip each...... They will rotate on their axis in the rail/manifold
IAC - Idle Air Controller - allows a SPECIFIC amount of air in the manifold during startup/warmup..... as temp rises, motor decreases in step count.....
ET - Engine Temperature sensor - Mounted in the front cylinder head, adjusts fuel dwell (Volume/time) and spark depending on combustion chamber temps....
MAP - Manifold Absolute Pressure - measures the amount of mainfold pressure to determine the volume/speed of air and amount of oxygen in the air along with the IAT (Intake Air Temp) sensor.....
Fuel pressure SHOULD be constant and not fluctuate with time or engine speed......
You should get a scanning type device to OBSERVE, MONITOR and COMPARE your observed values to specs located in the Electrical diagnostics manual.....
SERT, TwinScan and Digital Tech (HD shop Only) are what I am familiar with....
Old 12-04-2006 | 02:18 AM
Devil Dog's Avatar
Devil Dog
I know it takes time to answer questions and explain things but I sure do appreciate you doing it. I understand a little bit better now. I will do a search for the scanner you mentioned. Thanks again! Al.
Old 12-05-2006 | 07:34 PM
Deuce Bigelow's Avatar
Deuce Bigelow
SERT = Screamin' Eagle Race Tuner[8D]
much more control over the ECM and no add on box to worry about breaking.
Old 12-06-2006 | 01:31 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
What he said........you can tune it yourself 1000 times if you wish........If you tighten the mirror you can re-tune & adjust as needed then hit the upload button and you are there........it's like sending your bike an email...
ORIGINAL: Uno Deuce
Gordon61
The Dyno Room
17
10-28-2024 09:44 PM
hawg50
12-03-2014 10:47 AM
Fustercluck
EVO
07-12-2011 09:37 PM
Getyurmotorunnin
11-27-2009 12:03 PM
ScooterJammer
08-01-2007 09:52 AM
