Bas
I have a 2002 twinky with no spark code says
44 bas changed out with new HD part
Still same code and no spark checked wiring turs out
Green and brown wire is not connected wire chart
Says should be connected to #7 pin in the ECM
So I check the ECM conector wire is ther but at the
Next conector the wire changes to white and green
I can't seem to find where the green and brown wire
From the bas plug is supposed to be connected
When the bike first came to my shop I got it started
It ran for about five minutes and died then would not start
Checked the code and changed the bas and the coil but
Can't figure out what hapened the the green and brown wire
Or even if it was connected to begin with
Any help would be greatly appreciated
Thnx Jim Williams
Thnx Jim Williams
Is there a security system on the bike. If so the password may be lost.
http://www.harley-performance.com/password-learn.html
lonelyrider1966
10-26-2013 11:09 AM
Gadget_MD
07-11-2006 08:16 AM
