Coil Blows ECM Fuse?
Folks,
I am having an interesting problem on my 2003 FLHRI. Whenever I turn on the ignition I blow the 15A ECM fuse. This results in a constant CEL. It will turn over but will not start. I was checking for spark from the coil and noticed that the fuse will not blow with the coil disconnected. I have no schematics (yet) to reference. I can't begin to imagine how these two components (fuse/coil) are related.
The fuse should only supply operating voltage to the ECM. Is anyone aware of another connection between the two?
Thanks for any input.
Chip in Germany
Chip in Germany
RE: Blown ECM Fuse
I have a 2000FLHI . The ecm should take a 5 amp fuse . When my pc 3 went bad it blew the ecm fuse and it did the same thing you mention . Yes any thing that has to do with the running of our bikes will run through the ECM. Im thinking you have a burnt componant. I guss a stator or shorted voltage regulator could cause the ECM fuse to blew. I have a clymer harley davidson manual for 99 thru 2003 it has good wireing prints. Good luck post us what you found ride save brother,
[IMG]local://upfiles/3159/6ABA6E073E6F4E4ABD0483C89898145B.jpg[/IMG]
RE: Blown ECM Fuse
Thanks Turbo54,
I have the fuse in hand and it is indeed a 15A'er. I don't think I misread the cover but I saw ECM in that position. It is just to the right of the ECM. In the fuse block on the left (outside to in) is ECM, Fuel Pump, and Spare. The starter fuse is just to the right in the same block. It is a blue colored ATO style fuse marked 15A.
Also, aside from the V&H Oval slip ons and SE Breather Kit; my bike is stock. No Power Commander involved yet. It was remapped new at the dealer with stage one parameters...
RE: Blown ECM Fuse
Thanks All,
I'm in Germany and have a coil on order. I sure hope the ECM is not the problem. I have an extended warranty on my 2003FLHRI but the German Stealership will not recognize it.
I'll post my findings when I know...
p.s. Does anyone know what a normal coil should read in resistance across the winding?
RE: Blown ECM Fuse
ORIGINAL: Sleeps In Trees
Sux that they won't recognize your warranty. Did they say why? Sounds like something MOCO should be aware of...
VicW.
VicW.
