Has anyone used PowerCommander (extra features)
Has anyone enabled the extra features in the Power Commander PCIIIusb? on any 2007 Harley yet?
there are three:
1. the Fuel Pump addon that adds more fuel if you crack the throttle. It adds extra fuel above the map settings for a set amount of revoutions
2. The start up fuel adder feature (it adds fuel for a few seconds at startup only to help the motor start.)
3. The Rev Xtender? allows the bike to rev to higher RMP
Thanks for any tips on if you used any feature and what settings are you using (how much fuel for how long ..ect)
there are three:
RE: Has anyone used PowerCommander (extra features)
I didnt use the fueler, I understood that to be diesigned more for big inch builds that needed a little extra fuel to get started.
I did set my rev limiter up...no real reason though I never rev it that high...
the firmware has to be at 3.1.3 I think...very easy to do when yo have a laptop connected to the bike.
I did the accelerator pump. Yes, it works. A slight better throttle response was noted, but fuel mileage (as you would expect) went down. I hit a low of 33 mpg. I have backed off the accelerator pump settings a bit and it has helped. I might see 40 mpg someday soon, but riding the bike is about much more than MPG... More power just makes it more FUN!
F117EWO
F117EWO
Pittboy - any reason why the Accelerator Pump is not recommended for 2007 bikes?
The Start Up feature is on the same menu as the RevXtender. its the second check box I think.
I may just add a percent or 2 just to give it a bit more fuel on startup and for only a few revs.
Sounds like the Rev Xtender has no real issues so will check that
Accel Pump - guess wait what Pittboy finds out...
thanks for the quick replies everyone
When I ordered my PCIII from fuel moto, I mentioned the accelerator pump to Jamie and he did not recommend it for my application, "06" SG with SE slip ons and SE/AF. He did however recommend the rev extend. He didnt mention anything about a start up feature that adds more fuel.....................BG
I just enabled the RevXtender - I wasnt sure if you needed to send the map again so I did it after checking the box and hitting add feature then OK.
I tried unchecking the box afterwards but it kept giving me an error communicating to the PCIII USB. I was in communication because I could still send/rec maps to the unit. Also it would then recheck the box.
I also added 2% fuel for 120 Revolutions for starting. It made a noticable difference. I figured only 2 % more would not harm anything and the bike started almost instantly, vs without the startup enabled it would take about a 1/2 second before firing up. like it would hesitate. the instructions say 150 revolutions is normal. So I backed it down to 120 revolutions. then only add +2% of fuel.
