Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Most likely a broken cable. Easy check remove the cable from both ends, hold both ends, turn one end, if broken you will know. You could slide the drive cable out as well, just a little messy that way.
Thanks Guys absolutely right about the cable broke at the bottom end. You know I have been riding these things for a long time and always thought you had to change the whole thing including the speedo drive. Well this is why we all use forums and never go to Harley shops.
thanks again Popeye
