07 RK Tip Light Install
2007 FLHRC
Bought a used relocationl kit on Ebay. Seller said it was on his 02 RK. It is mostly 53702-04A. This is the typical streetglide original installation. 1st link below. But it has a tip light which has a connector on it in the box I received. No connector on the LED wires for the license plate on the bracket setup. Maybe he had the license lit differently. I dunno
The instructions available as PDF after expanding the 1st link make it clear that I am not supposed to have a tip light with the LED's lighting the plate. Is this an issue? I sort of want to connect both the LED's and the tip light to the same connector and plug it in but maybe there is a good reason for saying not to.
What I got did not include a light cover with no clear part up top. Looks like a replacement came in the kit according to the picture. Do these kits usually have a cover? Any reason I have to replace it right away? Any suggestions for what to replace it with if not whatever my friendly parts guy would sell me?
Thanks for reading
http://search.harley-davidson.com/?q=53702-04a&x=0&y=0
Thanks for reading
bpterb
08-09-2013 06:33 PM
UltraKla$$ic
04-25-2008 10:41 PM
