LED Problems
LED Problems
Ok I’ve had the Kuraykan Panacea light set up for a while and I started having a problem with the turn signals. Kept flashing rapidly and the security light came on. I changed out the load equalizers for another set that Kuraykan sent me, the one that is made for the security system with an additional equalizer added to it. Helped for about an hour, then just my left rapidly flashed.
So I purchased the Biketronics equalizer ($50) and installed that per their directions, still had rapid flashes. Took off the LED signals (per their directions), activated the turn signals, no faults, reinstalled LED’s, and they signal fine, but get the security light comes on after 4 flashes.
Any ideas??? I can also add the Kuraykan equalizers I have. I don’t like them because the get HOT and are not recommended with 4 way flashers.
RE: LED Problems
I had a similar problem, but could not get it resolved no matter what I tried.
In the end, I removed the equalizer, installed the LEDs in the rear turn indicator and left bulbs in the front. That seemed to work fine and I have not had any problems after 7 months.
Now I have a spare set of LEDs in case the rear ones crap out.
Atlantaclassic
Electrical/Lighting/Alarm
12-12-2017 08:58 AM
rangerider547
05-17-2016 03:41 PM
sdeck86
02-22-2015 04:53 AM
