Studder problem after hitting a pothole
Just when i thought all problems were solved. On my way home from work yesterday i hit a large pot hole in the road and my bike acted like it was running out of gas. Loosing power and hesitating. I made it about 100 yards and got off the road. The bike was idleing about 1400 rpm. I jiggled wires nothing worked so i shut it off. After about 2 minutes i fired it up and it ran fine the rest of the way home. home was about 20 miles.
Could the ECM or something just got a big jolt when i hit that hole that threw it out of wack for a minute? I hope this isnt more problems comming down the road,
Any Thoughts?
Thanks guys
Any Thoughts?
Thanks guys
Cold Case,
Im not familiar with the wording PCII or V. Could you enlighten me please? I do know i have Screaming Eagle Race Tuner. If thats what your talking about. I will check the ground wires when i get home tonight.
Im not very knowledgable on this stuff i probably know just enough to get myself into trouble...
Thanks
Thanks
If you have a SERT, you would not have a PC, the PC is another tuning device.
I don't know which bike you have, but if you do a search on ground or battery ground in the corresponding bike forum, you should get some tips. This is very common on a Dyna and there are photos in one of the posts there. Fairly simple to clean and tighten.... but you do need to know how to use a wrench
Same thing happened to me last year
Hit a deep pothole coming out of a driveway. Bike started to backfire and hesitate. Shut it down to inspect and when I started it up it was fine. Never had a problem like it again. Sometimes I think the ECM or PCV just don't like to be jarred too hard. Kinda like my brain.
Watch Guy,
That makes me feel better. I cant find anything loose. I just ran the bike up the freeway where there doing construction and hit alot of small bumps and the bike ran fine. I hope it was just that jar i hit the other day. It was pretty hard hit my butt flew in the air about 3 inches...haha
Time will tell i guess.
