setting static timing on my S&S 124
Just had it installed in my 98 Fatboy but am now home in Tennessee, it has a slight ping on load so I would like to see if they set it at the recommended position but am not really sure of the sequence?
1) remove plugs
2) remove inspection bolt
3) bring mark up to factory position
4) what about the battery...this is why I am confused.
Any help is appreciated. Doc
1) remove plugs
I don't know what you have to do, but you can read the instructions for it here! It is available via S&S's website, which is where I got the links from.
My reading is that if your motor was supplied as ready to install, you will see on page 7 that you shouldn't mess with the timing! I suggest you read them thoroughly then phone your builder, if you are not happy with the way it runs.
MotoOwner
16
03-30-2019 09:58 PM
mrbreeze
01-06-2006 08:21 PM
