Larger throttle body
Has anyone out there added a larger throttle body in the mix of changing pipes, airbox and SERT? I've only seen ads for Kuryakn's Wild Thing bigger bore throttle body. If the bike runs better with more air passing through, wouldn't this improve performance more? Any tech's with real knowledge?
RE: Larger throttle body
ORIGINAL: Redhead1
I'd like to see a 95 "cc" Road Glide. Is this a retro-fit with a law mower engine? 0-60 in... never! [sm=lol.gif]
http://cgi.ebay.com/Harley-Davidson-...QQcmdZViewItem
ORIGINAL: 2deuce
What restricts that air movement through the motor is the breather intake, the filter element, the throttle body, the throttle plate, the heads, the valves, and the exhaust. by adjusting any and all of these you can increase the performance of the motor.
Screaming Eagle has a 50mm throttle body with high flow injectors. This is a 4mm increase over the stock 06. I believe the Kuryakn's a 57mm.
Changing anything out on a EFI will require tuning.
