Sreaming Eagle pro race tuner help
hey guys new here, was wondering if you can help me out. i have a 2000 ultra and the guy i got it off had the pro race tuner. i tried connecting it to my laptop with windows 7 and i cant get any communication back from the bike for .
i am wondering if the latest version of windows has something to do with it and also, the tuner has a serial connection (9 pin) i gotta connector to USB for it.
does the tuner need to be connected via the serial port for the software to reconise it ? i also tried getting the updates but still doesnt help
thank u for your reply,
i have windows xp on my desktop but dont fell like bringing it to the garage if thats what it is. i got a laptop with windows 7 and a 9 pin to usb connector for the laptop and i cant get any communication to the bike. i have to have the software running and the ignition has to be on right ? the usb to 9 pin cable is made by sabrent and i made sure there was a driver for it which i installed.
it is the screaming eagle EFI race tuner kit and the software is version 4.000.006 on the tuner theres a few sets of numbers dont know what they mean if its any help 31215-03 and 08/31/07
Need to do a search on the sert to usb cable. Only a couple will work with it. You can contact TTS an get the correct usb cable.
https://www.hdforums.com/forum/elect...rt-to-usb.html
i must be doing something wrong. i brought out my destop with that has a seral connection in the back and i hooked it up directly to the tuner and i still dont get any commincation.
on my desktop i downloaded the latest version of the screaming eagle tuner, and i am running windows xp.
i connected the other end of the tuner to the bikes data port under the seat and turned the ignition on waited a few min and nothing happened. theres no led on the tuner its selft to let me know its working so, i cant tell if i am doing something wrong or its a bad cable.
Ok, did you have the kill/run switch in run postion ? There is no led or anything to tell it is connected. Go to file, then program ecm. It will bring up a box an you will see get ecm info an click on it an see what happens.
You are running 4.77 software ?
http://www.sendspace.com/file/q7d973
i just tried the 4.7 software u linked for me. thanks by the way. i ran it on the laptop with the usb to com cable and it still doesnt communicate with the bike it showed com 3 open and when i clicked to get the info it cant connect to the tuner.
i was doing a search on google and some guys were saying it could be the usb cable i have. i found a belkin f5u409ttcu cheap on ebay that i was thinking of grabing and trying. should i grab it ?
Did you put a check to enable com 3 ? I have been using one of the belkin with my toshiba netbook an win 7.
Or contact Mastertune an get one of there usb cables. Which is for sure to work for you. I have one of them also an works without a issue.
Call them an get the usb to module, you do not need from module to bike.
They also have the drivers for there usb cable.
http://www.mastertune.net/
sorry for not getting back right away. just had a chance to try it again. I also picked up a belkin cable and i was my newphews laptop with windows xp. the usb cable works fine i seen the lights flashing. i started the software, set the com port and tried to get ecm info but it still wont find the bike. i think its the tuner it selft. i have no way to test it eather.
