Need Help Please
Still no go. So far:
I swapped the battery with wif'es bike and it did fine with her bike.
Replace the negative battery cable and mad sure that all connections are tight.
Swapped the black box under the seat 2"/3" box, works fine on wife's bike.
Checked all fuses.
When I turn the switch on, there is the normal humming noise from the speedo,
but no lights, turn signals will not work, but horn works. The oil light and the neutral on the speedo do not light up, but the night light inside does light up.
It almost seams that the switch is the problem, but I would like to get more feedback before I start replacing parts.
Anyone ever have these symptoms? Any advise would be apprciated.
Checked all fuses.
dharanikanth.s
04-15-2014 06:39 PM
