need help with running problem...
Removed fuel pump assembly. Checked the soda straw looking tube that comes off the regulator and it had a leak, Aha! When fuel level got to the leak in the hose it would lose pressure. I replaced check valve/hose and gas filter while I was there. Test drove all was good till prob#2 decided to finally cause lose of voltage problem, but I didn't have my meter hooked up. Waited about 90 seconds and voltage returned and it cranked up and off I went. One down, one to go. I am pretty convinced I have a failing circuit breaker but want to prove it so went its fixed it's fixed. Thanks eleft, I just read your post after repairing exactly what you suggested. You ROCK!
PnDegc
15
08-01-2012 03:15 AM
