Power vision.... What next
Hello, This is sportyitalias husband ( I am using her login=lost my password), anyhow I have 2008 Fat Bob with 1.75 Rush slipons and a Fuel Moto SE Air Cleaner. I loaded the map for this application from Fuel Moto and follwed the instructions. It seems to run better, but how can I be sure it took the map? It just seems to be too easy. Should I investigate further or just run it?
No, they're not the same and I should pay more attention to the subject of the message. "Map" is usually a PCV term and "tune" is for PV, so that's my lame excuse for confusing the two.
Anyway, let me try again. There's more to the task with the PV and one more step is needed to flash the ECM. You will have the PVT file on your computer, the one FM sent you, so you will go into WinPV and load this tune file. Then click on "Send Tune," which will send the tune to the PV. The last step is to flash the tune to the ECM via the PV. To do that you'll disconnect the PV from the computer, make sure the PV is connected to the bike, and you'll interact with the PV with it connected to the bike with the ignition on (motor off):
1. Press "Load Tune"
2. Then, "Custom Tunes"
3. Select (highlight) the tune with the desired filename (the one you just saved)
4. Press "Select"
5. Flash
The process will take 30 sec. or so and finally instruct you to turn off the bike for 10 sec. After that your tune is in the ECM and you're ready to roll.
Thanks
Iclick, bike is flashed. It seemed too easy. Is there way to see what my pararmeters are on the tune sent from Fuel Moto. I have the driver and what not loaded on my computer. Can I see what HD had on the stock tune ? I was good to go as far as extracting stock tune from bike (SAVED TO SLOT 6) , my bike seems to run great . I am sorry for the dumb questions but i did my research here and decided on the Power Vision based on all of the positive responses. I really just want to verify that my tune went to my bike. The handheld said program loaded so I guess that we are OK. Thaks Again
