ECM Internal error
ECM Internal error
I have a 1997 ultra with EFI. I have made some changes, new cam, air filter kit, and pipes. After installing all of this I took the bike to the dealer to have the ecm reflashed. The dealer tells me they are not able to because they get an internal error. They told me it will connect and shows connected but anyway they try it they get the same problem.
So I ask how the bike can run then. I was told it was running rich enough with the MM injectors and they checked plugs and it was running great. I was also told to just keep running it until the ECM finally died.
My concern is I want it correct. The bike cuts out, hesitates, and does not run smoothly. In town driving sucks and when it gets hot as it is outside now it runs like crap. My check engine like comes on and off all the time and it is very aggravating.
The old guy who checked it told me I needed to have the hot idle cold idle set and it would improve. I am not sure I am buying that at this point. It seems like the ECM is not delivering fuel correctly.
I purchased an ECM from a friend who had a 1998 bike. My local dealer told me it would work on my bike since they were the same model. I am hoping it can be swapped out and the right software installed to get this bike running properly.
Anyone have any experience with this? Is the stock ECM bad? I need some help understanding this before I put anymore time or cash in this bike.
Internal problems occur with reprogramming or could be a case of don't want to go through the trouble of reflashing it. If your buddy gives you a ecm use his and take it to another dealer to get it flashed. Hot and cold idle will need to be adjusted based on your upgrades as well as some kind of tuner to get her to run right
2006ultra
02-13-2012 02:36 PM
