Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
it could be your crank position sencer very commen problem on the twin cam thats what went out on my 99 road king wasgetting no spark at the plugs good luck hope you get rolling soon
Quick check for a bad crank sensor is to see if you have an rpm signal at the tach since the crank sensor determines rpm. Hence no bounce on rpm during cranking = bad sensor
