SERT and Brazilian Fuel (20% alcohol)
Old 11-12-2006, 11:14 AM
paulocouto's Avatar
paulocouto
paulocouto is offline
4th Gear
Default RE: SERT and Brazilian Fuel (20% alcohol)
One_Screamin_Eagle, I mark all cells at AFR table and increment (lower the numbers) by 0.9, it meens when you see 14.3 you now see 13.4
it is more or less 8% (in this case is 6.3%, but when the cells was lower than 14.3, the percentage are bigger)
I did not change the VE tables yet.
I change only the AFR tables (as I describe), the idle RPM table (I need idle around 1050rpm), and spark timming table (advance 1 point when rpm is lower than 3000rpm), it meens when timming was 20.00 now shows 21.00. this timming adjust make my bike stronger below 3000rpm, before that it was a little soft.
my base map was the 1550 stII with 25 degrees. in this tryout I didnt change any constant. this new configuration is the better I try until now, and the bike runs very nice, with a lot of power. maybe I can tune better, but I think will be a marginal benefits.
I think VE Tables can be more espeficic to my cam (SE204 and not SE203, but I dont know how), and I think the spark timming can be more agressive, but I will spend a lot of time do test it (i will do that in future) using the data recording mode.
but in general, the bike runs much better than the original 1550 st2 map.
Old 11-12-2006, 11:55 AM
One_Screamin_Eagle's Avatar
One_Screamin_Eagle
One_Screamin_Eagle is offline
With a 95 - 100" motor, raising the VE 20 units roughly equates to lowering the af 1 point. You lowered the AF .9, so you did basically what I suggested in a different way. The problem with doing it in the AF tables is that they are supposed to represent what is coming out the tailpipe - in your case they do not, you are just using them to try to richen it up. I'm glad you are having success in your attempts.
Old 11-12-2006, 10:55 PM
Beagle1's Avatar
Beagle1
Beagle1 is offline
I owe you a huge apology.
I called my buddy back after your reply...Seeing as we were both on cell phones, and he was in a building, I didn't hear everything he said clearly enough.
It was supposed to be 50% more than the 6% we normally add to our 10% ehtanol fuel maps. Which would be about 9% like you discovered.
Sorry about that, you must have thought I was nuts. Tell you the truth, I was wondering too. Glad it's working for you.
HoggyMtnBreakdown
The Dyno Room
64
08-27-2017 09:10 AM
jimclaypool
11-06-2009 06:52 PM
mcouture
05-26-2008 08:28 AM
FLSTCI nut
09-29-2006 10:31 AM
TedMan
09-06-2006 01:26 PM
Quick Reply: SERT and Brazilian Fuel (20% alcohol)
