total electric power outage
2005 cvo fat boy nothing electrical has been added, main breaker was replaced with a 40 amp fuse some time ago,battery is good and passed a load test,it is not blowing any fuses and is throwing no codes.I installed a Dakota digital volt guage and it always shows around 13.5/14.00 volts when going down the road and that has remained the same.Bike runs great but has put me on the side of the road twice in the last week and I aint going anywhere on it until I figure this out.Sad because I ride it if it aint raining and I miss it.Power will go out as tho the switch has been turned off.switching switch and bumping switch does nothing.After 15/30 minutes all of a sudden you have power again.I have it in my shop with seat and fuel tank off checking it out.have taken the ignition switch apart and cleaned it, removed both battery cables to inspect them,removed and inspected the power cable that goes from lug on the starter to the main fuse where the circuit breaker use to be.While the power was off I did jog the kill switch on the right side handle bar and got nothing.Only other suspect that I can think of is the bank angle sensor but seams like that would throw a code if it was the cause.Anything else I should check? I know it could be the wire harness,but not going to dig into that yet.Anything else I should be aware of? THANKS! I got to ride again soon.
Tris S
General Topics/Tech Tips
05-15-2019 11:06 AM
