Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Most of the time my 93 Heritage runs fine but sometimes as I try to give it gas it will miss and backfire but still idle ok. Also it fouls the rear plug and if i change the plug all is ok again.
Any ideas i.e. leads,coil etc
If it's just the rear plug and happens to the new plug you install, I would suspect the plug wire as it is associated with only that cylinder. Also inspect ths coil around the rear plug wire turret for any cracking or carbon tracking. Is it gas fouled or oil fouled?
Pretty sure its oil fouled and as far as compression goes i redid the top end a year and a half ago. As I say its not constant and when I change the plug its good for a least a few days to a week Popeye
Sounds like you may have a ring or valve seal problem there. Try a compression test on that cylinder , then add about an ounce of motor oil to that cylinder and try it again. It will come up just a bit with just the oil, but if it comes up significantly, you have a ring problem, if not maybe a valve seal problem sucking the oil into the cylinder.
Thanks guys I found the problem A leaking rear head gasket. But it only farts when the bike is cold. When it warms up and the motor expands it seals and no more problem. I will redo the top end next winter. Cheers Popeye
