Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I'm looking for some help with my charging system. I have tested everything that I can and still get nothing. I have 0 to 0.2 Ohm from the regulator housing to ground. I replaced the factory Regulator with a new one. I have good AC Volts from the Stator. It starts great after I charge it of course. New battery. I have 1.0 and .7 Ohms at the stator plug. I can read hertz but get no amps with the multimeter. I'm starting to think the stator is fried. 2002 Dyna FXDX.
The stator puts out A/C volts, unplug the stator and put your leads in the plug coming out of the primary, set your meter to read A/C voltage, you should be like 30 volts at 2000 RPM. You can also check each lead from the stator for a short to ground.
Then your stator is fine. If your stator is putting out and you're getting no charge at the battery, it's either the regulator of a bad wire between the regulator and the battery.
