SERT vs. PCIII's accelorator pump
Hello,
The information you guys provide has been invaluable and greatly appreciated.... THANX!!
Like so many I am still somewhat undecided on which way to go.
I have on order eaglebeak slip-ons by rinehart and a big sucker for my 06 Springer Classic.
I was pretty close to going with the SERT when someone started pushing the PCIII and boasting about
it's accellerator pump feature.
Would I be correct to say that when the ECM senses the TP (throttle position) increasing at a high rate of speed it knows
the rider is asking for increased acceleration having the same resulting affect as the PCIII's accelorator pump?
Also; Is it true that Power Comander (Dynojet) would be more after-market friendly then SERT (HD)??
(I ask this because of the rinehart pipes).....rinehart suggested PC111.
George
George
RE: SERT vs. PCIII's accelorator pump
Correct me if Im wrong but I ve been told the PCIII accell pump feature is only for built motors and not recoomended for normal riding.
I have the PCIII for 15,000 miles. AWSOME. The accelerator pump is ok if you want to race around town. i have a bagger and it runs great without this feature. I disabled the accelerator pump because it used more fuel. It senses that you are turning the throttle and addes fuel just like the carberators on a car. Gives you added response when you need it. If you are a rider that constantly opens and closes the throttle then you will use a lot more fuel.
PCIII is user friendly. I can change pipes and retune in a short time. I can then change my pipes back and retune in a short time.
I can also add fuel at the 0% throttle position from 1250 RPM up to about 4000 RPM and it gets rid of the popping on decceleration.
Makes the bike run cooler but you can have a race map loded in 2 minutes if you are going to be racing around town with friends. Then I change it back to my fuel ecconomy map.
Had it dynotuned for $150 by Dynojet tuner. SERT takes a Harley tuner. They wanted $700.
Best thing I have added to this 06 Ultra yet. Love it.
ORIGINAL: jkoch06ultra
Not True. Anyone that understands air fuel ratios and can read their equipment can adjust the map tables with the sert and flash the ecm.
The ECM in your motorcycle is tunable by rpm, and speed. This is for the air fuel mixture and timing.
Understand that anything else that is put on the MC is taking the signal that the ecm is putting out and modifying that.
I bought a SERT. I will use the data mode to record the information that I need to modify a base map. By taking a laptop or tablet and connecting the sert you can ride and record up to 1 hour of data that can be used to modify a base map and program that to the ecm. You can do this as many times as necessary to get the adjustments correct.
Companies are selling add ons because most people don't understand the computers that are in the new machines. Then again remember your first pda?
I vote SERT
