Code won't clear
when after "end" is displayed i press and hold 5 seconds codes doesn't clear as stated here:
https://www.hdforums.com/m_327240/tm.htm
ORIGINAL: One_Screamin_Eagle
So you changed pipes or did something to make it other than stock. It means that the computer thinks that there was an absence of combustion. It will set after you get on the throttle. What's not factory on the bike?
Did you change spark plugs recently? If not, take it to the dealer and have them find the wire that is shorting... spark plug, coil, or otherwise. If you did, check the torque on the plugs. Or, it >could< be a bad plug... but that's not highly likely.
Since yours is an '07 I'm assuming that you haven't reached your 10k maintenance yet so you probably have a short somewhere instead of a plug torque problem. If it's compression related, then you should see the new error showing up under acceleration or high torque loads (climbing a big hill while accelerating).
I had the same error when I installed my new plugs and didn't use a torque wrench to set the plugs. I was a bit surprised at how much you put on the plugs... but I should have used anit-seize compound and then I wouldn't be concerned about getting them too tight.
C#
C#
ORIGINAL: KeithB
