turn signal problems
I have an 87 fxstc, when i hit my turn signals they would blink normal for a couple seconds then flash super fast until it would eventually be a solid light. well i put a new solid state flasher in and now it doesn't blink at all. it is just a solid light. cant figure it out. thanks for looking, matt
suspect a bad ground
Matt, many years ago, I had the same exact problem with a sportscar I owned. I know you're thinking "but I have a motorcycle!". True, but the principles are the same. In my case it was the left T/S doing this only. It would blink a few times, and then a steady light.
I had a very difficult time of tracing the cause of this problem. ( I had to remove the entire instrument panel, it was a rare Italian exotic, and I had no schematic to work from.)
The cause was a loose ground connection in the T/S wiring circuit. You will have to trace the wiring harness path and examine the wiring connection points. Betcha you're gonna find a loose or rusty connection. Especially likely, given the fact you have an older bike.
Tedious, yes, but think of all the money you will save DIY!
Hope this helps.
Ziggy
Hope this helps.
Ziggy
