Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I'm starting to build a 95bb stage 2 on a 06 eg classic. I plan on using the se204 cams instead of the 203's. My question is, can I use the same map as for the stage 2 with 203 cams or do I need to have a custom map done? Thanks for any help.
It's always best to do a custom map formulated on a dyno when using a Power Commander. The cams will allow the engine to breathe differently so there will be a difference in the maps. Check for a map which most closely resembles your configuration at PowerCommander.com
