PC-V issue
PC-V issue
Installed pc-v on my 2010 flhx back on February using maps from Dynojet and Fuelmoto.With either maps my fuel mileage has suffered big, my fuel mileage with pc is at 30-32 mpg.Thats highway and city driving and throttle response is also poor, have also noticed that front plug is dark and sooty compared to rear which is clean and slightly dark around the insulator.If I go back to stock everything is back to normal,40-42 mpg,equally clean plugs,and better throttle response.Any help would be appreciated,I hope its not a faulty PC. Ordered PC-V from Fuelmoto.
This will reduce fuel 5% in that range, which is where you likely spend most of your time. It won't help if you are into the throttle a lot, and should increase mileage while you are cruising at highway speeds.
Make sure your PCV isn't configured to enable the accelerator-pump feature, as that will affect mileage adversely.
iclick I am not happy with going back to stock,that is why I ordered the PC-V from fuelmoto.But I am not happy with the poor mileage and throttle response.Thats why I emailed Jamie last week(5-24-11),and I have not received an answer.Could be that he is probably swamped with other customers,I'll just have to wait and see if I can get answer by the end of the week.
when i had a pc-v on my bike i had a problem with it and he contacted me while he was on vacation or away from the shop .if he knows your trying to contact him he will get back.
they do have very good customer service.try the phone number they provide and tell them the problem your having.
kyleplusitunes
12-27-2011 04:57 PM
