Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I'm setting up my 2010 Dyna Wide Glide with a S.E. a/c and Rush 2" slip on mufflers, everything else is stock. Does any one have a good TTS Mastertune map for this set up? Thanks.
You would be better off doing some good "V" tune runs and building your own.
No two bikes are the exact same. Load the closest base map and have fun running the "V" tunes.
I'm looking for a good starting point. The closes base map I could find is CAE176-03, but is that the best one for my set up or is there a better one to start with?
It looks like you could go with that one or CPZ176-03. Your choice is probably the one I would work with first.
