need help - SE super tuner vs PCV
Sounds good. I know you're going to have good results with your setup. I really like setting up my AFR tables like the one I posted, it seams to be good all around. Nice and lean for good fuel economy in the cruising and nice and rich in idle and higher load and RPM settings. Out of the hundreds of bikes i've tuned, havn't had any complaints yet.
yes, this AFR table will work on al setups. Just keep in mind that some MAPs have differn't load ranges and RPM's than others. But the same concept if fine.
I don't have any on hand experience with the Power Vision, but from everything i've read it sounds like a great product. With Fuel Moto and people like Iclick there is great support on this forum. I have only read a few negatives about it and they've only been software related (as is expected with any new technology) but I believe they have any issues resolved.
Yes you are correct. I usually set them to 14.5 in cruising on pre o2 sensor bikes that don't have closed loop as well. Since the bike is running solely on the tune.
What do you think? If kept the wide-band sensors I could datalog at any time and adjust the map throughout the engine's operational range, but of course it will be running in open-loop at all times since the stock ECM can't run in closed-loop with them. Please tell me it's a harebrained idea, because I really don't want to bother with it, and I would hate to remove all this neat high-tech hardware.
I just installed the AT-100 cables a few days ago and have yet to perform a tuning datalog session, but have been doing some datalogging just for practice. These CSV logs can be viewed in MS Excel and are used by the PV Tune software along with several ECM parameters to create tunes. It isn't as complex as it sounds.
If anyone is interested in following the sticky PV thread in the ECM/tuning section, please feel free to participate.
Along with the Power Vision, I have the AT-100 (wide-band) option attached that's left-over from the PCV-AT setup I had before. Since my present tune is based on auto-tuning with the PCV for two years, I was thinking about using the VE tables this created and re-installing the NB O2 sensors. I don't think they would make much difference, but would keep it at stoich in the cruise range. I'm monitoring Lambda values in real time with the PV LCD display unit and it seems to be holding the line at near Lambda 1.0 most of the time in open-loop mode, not veering either way very much (maybe .99-1.01 most of the time). For that reason I tend to think adding the NB sensors might not be of any practical value. Even if they were re-installed I don't think AFR's will stay much closer to stoich than what I'm seeing now. The MAP and other sensors will adjust in open-loop mode for altitude, temperature, etc.
And as much as you like to experiment, I thnk you'd be bummed out without datalogging.
Yes, I think I can get more out of the PV with the WB sensors, so thanks for backing-up my prejudices! I'll be doing some tuning soon using your AFR tables. BTW, just out of curiosity, why did you insert 12.8 from 5000+ @ 20-60 KPA? That sounds a bit rich when you're presumably decelerating in that range. I had it set to 14.0 there in my PCV-AT Target AFR tables, but I had no rational basis for doing it. It just sounded like a good number to put there. I notice that Jamie uses 12.9 there, even up to 80% TP.
Actaully, I didn't make changes to those areas of the MAP, that is the stock, "canned" setting from SE. but to answer your question, those RPM and MAP ranges are typically only seen under deceleration, so I leave them rich to aid in decel popping.
Sorry to sidetrack this for one quick question, but on stock bike is it possible for an 02 to go bad? If it does will it make the bike lean out? Only reason I asked is the front cylinder O2 had some black on the sensor while the rear was a chalky white... With the new exhaust now I can clearly see its leaned itself out since the pipe was glowing red. Thanks for any info and sorry to hijack.
