02 FLSTCI still sputtters at low speeds after top end rebuild
Old 05-14-2011 | 12:20 AM
sincityharley's Avatar
sincityharley
Default 02 FLSTCI still sputtters at low speeds after top end rebuild
I just finished with a full top end rebuild. I only did the rebuild because I thought there was an intake leak causing the sputtering. This was only after I pulled the tank and replaced all the hoses inside the tank and tested the fuel pump. I replaced the plugs and plug wires. I replaced the TPS. At this point I have replaced just about everything. After the rebuild the bike ran perfectly for 3 days. The first day that i decided to open it up just a little bit, it starts sputtering again just like before the rebuild. If I open the throttle enough the sputtering mostly stops. Its definitely more prevalent at lower speeds but still happens every once in a while at higher speeds. At this point I am thinking the problem could be the ECM, fuel injectors or the two larger square fuses under the seat. Can the ECM lose its tune? Is there a way to test the fuel injectors? I'm planning on buying the fuses tomorrow. I cant believe the bike is still having issues. I could use some advice. Anyone have any suggestions?
blue06flhri
09-09-2018 11:08 PM
Mike Lawless
03-21-2017 12:45 PM
Navyrep1
07-11-2011 02:27 PM
OneBlackFly
04-23-2008 09:40 AM
jcknapp
02-17-2006 07:15 PM
Quick Reply: 02 FLSTCI still sputtters at low speeds after top end rebuild
