No speedometer/odometer
My 2005 roadking speedometer and odometer quit working. The security key light stays on while the bike is running. The security system is working and the bike runs fine, just no speedo. I pulled the speed sensor and cleaned it but that didnt fix it. Fuses are all ok. Need help with diagnosis and repair.
there are a few links on here for troubleshooting your turn signal security module which is indicative of the the things you mention.
Did you go through the diagnostics codes your bike is throwing? You can access that troubleshooting guide from here.
https://www.hdforums.com/forum/gener...odes-dtcs.html
Check that out.
Check that out.
nginfour
04-24-2007 01:03 AM
