Bike won't start, battery good, loud ding *videos*
Went to a bike night Saturday night. Time to leave, bike wouldn't start. Tried to jump it no luck. Had battery tested, it's fine. Pulled my car battery, connected it to bike, still no start. When I turn switch to Acc things light up. When I turn to IGN I hear a loud ping or ding as well as clicks. When try to start it, the lights flicker 3 or 4 times and I hear clicks with the lights, then everything goes dead. I posted videos of what's happening here on youtube. Anybody have any ideas? Diagnosing electrical problems is not my strength.
http://www.youtube.com/watch?v=bQ9DF9w3-Dg
http://www.youtube.com/watch?v=jR2qok8uU1w
My buddy had the same issue.....it turned out to be the positive battery cable....it looked fine on both ends but, inside the cable it had corroded and was only making a connection strong enough to run lights but as soon as you hit the ignition click click click....Funny thing is, a guy on the scene kept saying sounds like maybe the positive battery cable is shot and we blew him off saying we had used and Ohm meter to check it....he used some thick wiring to bypass the positive cable to the starter and she cranked right up.....DOH!!!!
Bike won't idle
I have been running a Thunder Max Tuner ECM on my 07 Ultra Classic for about 3 years with no problems. Couple of weeks ago I tried to start bike and couldn't. It cranked hard but would not turn over. Of course I checked the codes on TMAX and saw none. I found out that by giving it some trottle when starting it would start and bike runs normally until I come to a stop and motor will stall unless I keep giving it some gas. I disconnected the TMAX and connected stock ECM and have the same starting and no idle results. I am starting to believe something is wrong with the IAC or some sensor having to do with the idling process. Help would be greatly appreciated.
I am glad it got worked out for you and I would like to thank you for posting the ultimate solution!!! Posting the solutions to these problems is helpful to everyone else on the board, and sometimes folks do not take the time to do that. Ride safe!
