realtime afr
realtime afr
hooked up pcv auto tune, updated software and firmware, enabled. do not see realtime afr anywhere, am i missing something? also bought from fuelmoto, just got today and instead of 2 at modules got one that i was able to wire both to, is this new? is one still front and two back? thanks for your input ahead of time
1 is front and 2 is back
I got the AT from FM as well. The instructions left a lot to be desired. It took me quite a few tries before I got it working too. Check and re-check the wires that plug into the module. What a cheap idea for wiring. Everything else connects with proper plugs but noooooooooooooooooooo, not the AT. Also recheck the software/firmware updates. Sorry but that's all I can tell you. Maybe try FM during business hours if you still can't get it working.
i don't know if it is working or not. have 1.04 software and 1.02 firmware. when bike is running light on at blinks 3 times twice then is solid. have not been able to take for a ride yet so cant check trims. didnt know that at was just one module now and not two like all the literature and pics show. i dont know about realtime afr were it is or anything. hopefully i will get to take it for a ride in the next couple of days.
