Need Electrical Diagnsis Help
Ok, which fuse is it that's blowing? ACC fuse or different? Areas to check if it's ACC fuse is rear fender (tire could've rubbed through wiring) or more importantly, pop off the fairing and check the wiring near the brackets (they've been known to rub through) You might even find a broken fairing bracket while you're in there.
It's fuse #1, a 15 amp fuse for the instruments. Which fuse does the harness near the tire blow? I havent pulled the fairing off but I will. I just put a new rear tire on this morning and I wish I had looked at the harness while I was in there. I have looked under the seat and the side panels but haven't seen anything unusual.
