TTS CAA 176 map - be careful
FWIW,
My set up is almost dead on to the mods this map is set up for and my bike pinged like hell when accelerating. I just hope no permanent damage was done......I took it easy and limped on home once i realized it was detonation- it's a wierd high pitched tinging sound. Tuners around here are not up to speed to correctly tune TTS so I guess it's up to me to figure out how to V tune now.
FWIW,
Yes, the cams are the only difference, The map callls for SE 255's and I'm running the new 48H which are very close in spec but not a perfect match.
I have already reloaded another map that doesnt ping at all but now it farts through the carb and hesitates when rolling out from a stop until the motor is fully warmed up- then it runs just fine.
Not many tuners in San Antonio are TTS savy which is making it tough to dial things in....
Any pointers to clean up the cold hesitation issue until I find a reliabel tuner here??
I have never vtuned before and it seems complicated; even more so with the new cam selector function. I have no problem diving in but confidence level is low
That helped out immensely!! Almost pefrect now!! Thanks so much.....
Weeboy1
06-10-2015 02:49 PM
