Taylor made wires
I have a set of 8MM wires that I cut to length and crimped on the coil ends. When I pulled the stock wires at the coil end, the stock wires have the white sleeve and small contact surface.
When I plugged in the Taylor wires they do not seem to lock into the stock coil. Because I have to lift the tank just to gain access I do not want to have to do this again.
Anyone one use the after market wires, or should I go back to stock? Any other advice?
